Since I first bought my 2 Reach RS units in June 2017 I’ve never been able to connect them to the internet to be able to perform upgrades.
I’ve tried 6 different devices so far - 2 x MacBooks, an iPad, 2 x iPhones and an Android pad.
I’ve had to send the units to an agent to get them reflashed and that got them working but it was just before 2.16 came out with the new stake out mode etc.
And so I am trying to connect these units to the internet to upgrade them — stuffed if I know what I am doing wrong as I have followed every instruction I can find and yet…
This is the screen I get to on every device.
If someone could free me of this frustration I would be most grateful.
Simply connect your device to that same network as reach just connected to and use fingapp to get the ip address reach now has ,input that address into your browser then you should be set . Good Luck
You will notice when you press to connect to a network the blue will flashrapidly (searching for networks), if it connects it will blink slowly (connected) , and if it goes back to solid (hotspot) connect to reach hotspot again and try again , check if password is correct.
