Caster Down Today?
Regular user of Emlid Caster.
I can’t log in via web browser to caster.emlid.com today - it spins for a while then kicks back to the logged out main welcome screen at caster.emlid.com.
Using Emlid RS2+ as base, either over WiFi or over SIM card cellular with same profile that has been working for years, it does not appear that the rover (RS2) can connect to the NTRIP mount point. Not receiving corrections.
Usually my first troubleshooting step is to log into the web portal and make sure the base head is connected to the NTRIP upload - but that is also not possible today.
I’ve double checked the networking paths, wifi/bluetooth connections, and have tried to do the upload from the base from both the internal SIM card over cellular and over an external WiFi hotspot.
Can anyone confirm the Emlid Caster service is having issues?
Checking, I can confirm there seems to be an issue.
I did get through, but it wasn’t smooth.
Yes I am having similar issues, the page does load some of the time, but others I get a gateway error.
Hopefully someone can look into this quickly!
Same issue here, getting 502 bad gateway. Any ideas
Hi guys,
We are experiencing an unexpected slowdown of the client that handles the login and the mountpoints of Emlid Caster.
Our developers are investigating the cause of this issue. Until then, the only thing that can help is to wait a little and try logging in again.
If a LoRa setup is available for you, it can also be a good alternative.
Firing up here on the west coast, USA and seeing this issue as well. Any update?
Can you post your work-around that allowed you success?
Nothing special. I just kept trying. Not sure what the issue is, but it seems to be intermittent.
Is the issue just with logging into the Caster website, or it also impacting the caster’s corrections casting to the field?
Hi @chasee, the issue is with the login part. If you have an issue with the corrections, feel free to let me know. I will help to troubleshoot the issue.
@merryna.anggriani this appears to still be an issue. Is Emlid still looking into this?
Error 502 Bad Gateway
Yes, we are still looking into this issue. Once there are any updates, I’ll let you know!
Can anyone confirme the Caster Emlid service is down?
Error 502 Bad Gateway…
Cheers!
Hi Jose, this is the issue with the login page. If you have an active correction, it should still be transmitting without issue. We are still working on fixing it. Please wait for 5-10 minutes and try to re-login. Thank you!
I think the whole system has been malfunctioning lately. My permanent station has the same configuration as always, but besides having a lot of trouble accessing the Emlid Caster website, it keeps disconnecting, switching between online and offline every few seconds. I don’t really know what’s wrong, but it’s been malfunctioning for several days now (at least for me).
Hi Ian,
seems to be a global problem. I also have had the ‘ not receiving connections ‘ message for some time. Like you I had not changed anything.
Getting a 2nd receiver and using LoRa has been the solution for me.
Seems it’s either the Caster service, or, could it have to do with the dropping of the 3G network, which I understand is also global.
best wishes,
cheery,O
Hi @DiegoARG,
Please ensure the internet connection. If the issue still persists despite a stable internet connection, please share the following data to [email protected]
  • mount point
  • email address related to the account
  • time of the issue and the time zone
I will check it further, thanks!
Since Friday evening
502 Bad Gateway when attempting to sign-in at NTRIP Caster Land Survey Software | Emlid
Screenshot 2026-03-28 101246
I’m not able to sign into caster.emlid.com. I am getting a “502 Bad Gateway” error with the letters: nginx
I have tried clearing cache, running in private mode with both Chrome and Edge on two separate machines. Any ideas?
