Caster Down Today?
Thank you for sending the email! We received your email. Let’s continue the troubleshooting there.
This “502 Bad Gateway” is related to the login issue. For now, please wait 5-10 minutes and try to re-login.
I suspect they have a server/router having hiccups….assuming their pipe is big enough, and server/router can deal with the traffic. On the rover side below…which indicates no response, but when tried again, it worked.
Screenshot 2026-04-01 114957
Hi, this is Arnaud from French Polynesia.
I wanted to use Emlid Caster service in Reao (Tuamotu) to transmit the corrections via NTRIP Caster service.
When i attempt to sign up for emlid caster, I still have the same issue (i.e 502 bad gateway)
I tried to login many times, with no success. Can Emlid support fix that problem? so I can use the Emlid caster service ? It does not seem to be an internet problem nor a browser problem…
Thank you very much.
Hi Arnaud,
We have been experiencing an issue with Emlid Caster’s website, which sometimes doesn’t load. Waiting for 5-10 minutes and reloading the browser can help. As a note, if everything has been set up, corrections shouldn’t be affected even if the website isn’t responding. We are currently working on addressing the issue. I will share in the thread once we have any updates.
Hi Alexandra,
Thank you so much for your quick answer. It finally worked out, I waited about a couple of hours and finally I could login and got my mount points credentials.
Regards,
Arnaud
Hi @arnaud.jacob.theo ,
Thank you for the update! I am happy to hear you were able to get the credentials. I will be sure to let you know once there are any updates on this issue.
Is there any update on this issue? Thank you
Hello @rpage ,
We don’t have any updates yet. I will let you know once I have any news on the issue.
I believe it may be related to a delay so that the packet(s) sent are held up in a buffer, and then released. Works fine, once connected.
I’m still getting nginx 502 bad gateway errors, on the login page and our rovers are no longer seeing corrections. I have no way to log in and diagnose or troubleshoot the issue.
I’m surprised that this issue has been happening since March and there is still no real solution.
Hi. I know this has been an ongoing, irritating problem but I thought it was worth mentioning that I also repeatedly have been unable to log on. I have one base station which still seems to be able to transmit corrections through the caster, because my drone is able to receive them. However, I can’t get on the caster website to verify status.
Although “wait a while” to be able to try to log in, has worked at times over the last few months, it has also burned valuable time when I show up to a job site to get set up! Not to mention the bad impression it makes when clients see the unreliability of what they already believe to be “2nd tier” lower quality equipment – which I happen to love and recommend - but it is letting me down!
Also - to be clear - even when logged in, the page showing the mount points and status fails to load reliably. Ooops, there we go. The status webpage just popped up after an hour of trying.
Just so you understand - tomorrow I have to make a good appearance at a new client, and a caster is the only way to get corrections to the drone. (of course PPK on the images is still a fallback option).
We’ll get it done one way or the other… but the caster option is the most elegant!
btw, this is in Virginia, USA.
Try GeoAstra NTRIP Caster . The free version works well, although some limitations around multiple users.
I’ve been trying to use GeoAstra’s NTRIP Caster but have had no success in connecting to it. Have you been able to, and if so, could you post some instructions? Thanks so much either way in suggesting another NTRIP Caster!
I guess I should mention that I have a RS2+ rover and my base is a Sparkfun Mosiac X5. The base is fixed. Using the Septentrio interface it was fairly easy to configure the Geo Astra Caster, much the same as the Emlid Caster, but I vaguely remember that the user name needed to “pasted” because I couldn’t enter all the characters on the Septentrio interface - something like that… Sorry, I did it a few months ago. Have you logged into the Geo Astra webpage and checked the caster details? Hopefully this may be of some help?
Hi @NUS ,
The correction transmission through Emlid Caster should work properly. The issue occurs only while the webpage is getting loaded, as the system keeps rebooting. However, once you get the credentials for your base and rover, they will work just fine. You can take a screenshot and save it, so you won’t need to access the login page every time you configure the devices.
We are currently working on the issue; however, it’s quite a complex process that will require some time. It’s one of our top priorities at the moment. I will be sure to share in the thread as soon as there are any updates.
If you are having issues with corrections once you have the credentials, don’t hesitate to let me know. I will be happy to help you out.
Sadly no, for whatever reason my RS4 doesn’t seem to want to connect to another NTRIP Caster that isn’t Emlid’s. I may try to find another caster besides Geo Astra. Thanks again!
Hi everyone,
We’ve made some updates to Emlid Caster to improve stability, based on your feedback. You should notice things running more smoothly now, as the web browser is now more reliable. Feel free to share any feedback you have.
