We have just received and set up a new RS+ unit using an android tablet as the wifi device and an android phone as the mobile hotspot. Wifi and hotspot connections are fine and we are able to view the status of the rover. However, we are not seeing any status bars for the base (the rover is reading 20-25 satellites, base 0) and the solution status has not shifted from single to fixed. I believe the problem is either the base mode corrections (we have used the IP address for the android phone with other default settings) or the correction input (we used instructions from another lab group in the NTRIP tab - maybe there are defaults that we can use here?)
Any help would be appreciated as we’re hoping to make use of this unit in the next few days.
