Good morning to all
As I am not sure I understand.
I am planning to buy a second RS2 and use it as a base.
I didn’t understand what is the correct way to use it so could you please help ?
Scenario 1: place with good internet coverage and no known landmark.
Connect the base to NTRIP and share corrections to Rover via LoRa?
Or do I need PPP first?
Scenario 2 : area with no Internet coverage and no known landmark?
PPP only?
If you have NTRIP available, the easist thing to do is to setup with a 30 min Average fix on the base, and then get going with your rover over LoRa. Continue to collect NTRIP and Base raw-data, and then when you come home, you can PPK the exact base coordinates with many hours of data (especially needed for long baselines), and the adjust your rover-data with the difference between the 30 min avg fix and the PPK’ed position.
PPP, or get Rinex data from a CORS up to 100 km away. Depending on how long you observe the point, distance to nearest CORS and how fast you need the coordinate, your preferred option may vary.
