Hi Svetlana,
I use your caster with my Autel Enterprise RTK with no issues. Port 2101 works fine. If we could use that port that would be great. I read and can no longer find the port issues are with there app not work with certain port ranges.
My autel evoII enterprise works fine with caster.emlid.com
Thank you all! Now, Iām going to confirm with devs there are no restrictions on using the 2101 port for local NTRIP.
Iāll get back with the news.
Hi everyone,
I invite you to test the 28.2 firmware Weāve changed the port for the Local NTRIP Caster to 2101. Super excited to hear your feedback!
By the way, we also updated our guide about integration with DJI Phantom 4 RTK and Reach RS2.
Thank you for what you do for us. You are very efficient and close to our needs. This is what sets you apart from the rest of the world.
Iām sorry, I donāt want to disappoint you but it still doesnāt work for me.
Mi dispiace, non vorrei deludervi ma a me continua a non funzionare.
Can you share your Emlid Caster settings?
Thatās the NTRIP profile for the RS2 right? I was looking for the actual Emlid Caster configuration screen. I havenāt used it in a while so the interface may have changed. I can look at mine later as well.
No sorry what I posted is local ntrip not emild caster. They are two different things.
Sorry Svetlana,
I have a doubt, are you using the standard protocol RTCM 3 or 3.2 format?
Also it seems to be an account or password issue.
Maybe the IP issue? Can you test with RS2 Wifi itself? IP should be 192.168.42.1
Nothing changes, it says itās a problem of incorrect account or password. But with dji phantom 4 rtk is everything fine?
Hello,
There is no feedback, so itās just my problem? Where am I wrong?
Thank you
Hi Antonio,
Iām really sorry to hear there are still difficulties. Letās try to sort them out.
Reach RS2 support RTCM3.2 and also legacy messages. Do you think Autel requires RTCM3? The error message doesnāt look like itās the cause of the issue.
Iāve tested it with two Reach RS2, and there are no issues. I agree itās not the same as with Autel drone. But it means the feature itself works fine.
Maybe Autel waits for some specific credentials? I mean, the exact number of characters or something. Iād ask you to clarify with Autel support what could cause this error.
Weāre ready to help, but we need to know the exact reason.
Iām having the same problem with the Autel EVO2 RTK, the network protocol is NTRIP V1 or V2?, I have tested with the local NTRIP with the Lefebure app and with NTRIP v2 set up it doesnāt connect.
I donāt believe is something about an exact number of character because with the emlid caster it works fine.
