I have tried to use GPS-only logging 14Hz with the latest update (2.2.1). Unfortunately post processing isn’t working. rtkpost_emlid_b26.exe either runs out of memory or, when I choose only 20 min the result is very bad (<5% Q1, strange positions).
Never had such a problem before with 10Hz.
Here are 30 min logs (convertet with rtkconv_emlid_b26.exe)
Thank you very much!
But it did not solve the problem. My laptop has 16GB RAM, the process stops when using approx. 450MB RAM.
A new file appeared: .hnav
@tobias-dahms It looks like it was not the problem that you are seeing. I was able to process your data without seeing the memory allocation error, but the observations of the base unit are looking really bad. Cycle slips everywhere.
Base station data is basically unusable. I have tried to process the rover data (which is good) against the reference station, but the baseline is about 57km, so no fixed solution. The track looks like you walked around something approximately 20m wide
Ok, that is strange, had no problems some days before with another observation. The base was in the open field, only some leafless trees 50m away. The rover was very close to the trees in the beginning. I use the ground planes etc. for the rover and the base.
Hy Emlid team
Can i upload my Static observation and Base rinex to try to post process ?= because I’m not able …maybe there is something wrong in my workflow
