Hy
the zip files are too big where I can Upload ? (65mb in tot)
Francesco
Hy
Francesco
Dropbox?
I think that you should put your base in better conditions.
Not many cycle slips, but bad satellite visibility.
Hi! b27 does not work for me. I have b26 and b27 side by side. With one of the recent logs I have 77.3% Q1 and 22.7% Q2 using b26 while Q=0 for the whole flight with b27. I double checked and all the files are the same, all the settings are the same.
base_201702041316.obs (7.6 MB)
seems like there is some problem with RTKCONV, the file above is converted with b26 the other one below is with b27
if you go inside you will see that b27 corrupted the date to 11th of february instead of the real 4th (as indicated by the filename also)
Ok, thank you for the information, I will try a better spot next time. Had many good experiences with semi ideal spots, but maybe it was bad luck that time.
