I am looking to log raw data for post processing using the Navio+
I was not aware that the chip does not output RAW files natively when I purchased it.
I have enabled logging of the raw data by adjusting the ubx_spi_m8n_glo_raw_1hz.cmd file with this
!UBX CFG-GNSS 0 32 32 1 3 16 16 0 0
!UBX CFG-GNSS 0 32 32 1 6 16 16 0 1
!UBX CFG-MSG 3 16 0 0 0 1 0 0
!UBX CFG-MSG 3 15 0 0 0 1 0 0
!UBX CFG-MSG 1 32 0 0 0 1 0 0
!UBX CFG-MSG 3 16 0 0 0 0 0 0
!UBX CFG-MSG 3 15 0 0 0 0 0 0
!UBX CFG-MSG 1 32 0 0 0 0 0 0
However the log file is literally a .log file which when put into the conversion program (the one found in rtklib) it spits out nothing. I thought it should generate a .ubx file?
Is is possible to convert the data created by the Navio+ (M8n) into Rinex format?
Sorry I am very new to all this any help greatly appreciated.
Has anyone actually gotten a RAW log out of the Navio+ ?
the .log files can not be converted to Rinex with the converter. Also it does not make sense to me that the ublox would output a .log file. It should be a .ubx
of course you can specify the .log file extension in the conf file but this again does not makes sense to me.
I am hopeful that it is something simple I am missing
