Liked seeing the Navio + on the quad and the flight. While I appreciate, it’s just an example, can you provide the details of the components for your quad build and any differences to keep in mind if using the initial version of the Navio? Thanks.
Sure!
In our build we used:
FPV250 frame
4 x Emax 12A ESCs
4 x ZMR 1804 motors
1300mAh 2S Li-Po
Navio+ (RPi A+)
Power module
For Navio only difference is in power module. Navio is powered from dual BECs. On a quad you can simply use two built-in BECs from ESCs.
Nice hardware, lower power than mine, are you up for upside-down flight?
