I am trying to use the XYZ coordinates for my project but need some clarification;
the output of the Emlid looks like this;
Date YMD; Time UTC; X; Y; Z; Q; NS; Sdn; Sde; Sdu; Sdne; Sdeu; Sdun; Age; Ratio;
2020/12/22 04:09:21.000 -1428457.0271 -3517077.7930 5109034.7497 5 13 0.4026 0.2311 0.9605 0.0000 0.0000 0.0000 0.00 0.0 (END = HEX 0x0A)
What these Sigma are? Why are they relevant?
SDN?
SDE?
SDU?
SDNE?
SDEU?
SDUN?
I need to find a way to create messages including
message 1
Xvelocity?are these in the Emlid output?
YVelocity?
ZVelocity?
Bias Rate in m/s? I am guessing i will calculate this.
Time of fix GPS seconds (will have to back calculate this)
message 2
X position, in emlid output
Y position, in emlid output
clock bias in meters? Guessing i will need to calculate of fudge this number.
Time of fix in seconds (will need to back calculate)
message 3 Sigma info
time of fix (back calculate)
rms, in emlid output "Ratio Factor?
sigma east? sde or sdeu?
sigma north?
covariance E-N? Calculate or guess
Sigma Up?
Semi major axis m? Calculate or Guess
Semi minor axis m? Calculate or Guess
orientation radians from true north? Calculate or Guess
Yes i have read the RTK lib manual, and yes it does not explain anything other than XYZ position only in the output on page 102. And Yes I have googled and searched this subject both on the web and this site.
I am on the fence if it will be easier to use xyz, llh or nmea, either way i will have to back calculate some, spoof others, and guess and check a few. I just need to find which format is the most complete.
But I really need to know the fully explained plain english description of the output fields of Emlids XYZ format please. That way i will know what messages i do not have to scavenge for.
