Wrong datum choosen in emlid flow project
  1. Emlid Flow app version
11.3
  1. The name and parameters of the coordinate system you work with.
Base SC worlwide, Project in Emlid flow Nad(83) MTM 7 and CGVD28(1997) for heights
  1. Detailed issue description. How does observed behavior differ from the expected one?
Can I correct the situation by creating a new project in Emlid Flow 360 with SC wolrwide and importing the CSV file and downloading it again
Thank you
Hi @jtremblay,
Welcome to the Community Forum!
You can correct the situation by creating a new project in Emlid Flow 360 with SC Worldwide/Global CS as the coordinate system. To do this, import the collected points first. Then, change the coordinate system by clicking on the three dots in the right corner, selecting Edit Info, and navigating to Coordinate System. Choose from the library and select NAD83(CSRS) / MTM Zone 7 for horizontal coordinates and CGVD28(1997) for vertical height.
Once you’ve set the coordinate system, you can import your CSV file and download the corrected data.
