Hi everyone, i’m a new buyer of the Reach RS2, arrived today and tested to see everything works.
Worked before in a Civile Engineering society with an old Leica GPS1200.
Now started freelance and needed something affordable and the Emlid it seems a great value GNSS reciever.
Tried to collect some point in with NTRIP correction from GNCASTER that seems to work in ETRF2000, using the CS Monte Mario/Italy Zone 2 (EPSG 3004), but the coordinates are wrong when i put it on a base map oriented in that CS.
If I use that app Ferens + - UMBRIAGEO (regione.umbria.it) to convert the LLH collected in WGS84 system reported in the same .csv, the coordinates are correct.
Is the issue correlated with the CS i set on Reachview 3?
Under i report the .csv for one point
1008,2287342.474,4785418.925,308.818,Prk,12.13720597,43.18494621,308.818,0.022,0.023,0.024,0.032,2.134,FIX,2021-05-21 16:14:23.5 UTC+02:00,2021-05-21 16:14:28.5 UTC+02:00,25,3.2,2283557.596,4787483.331,304.356,4310.108
