Hi Emlid,
At the moment I am working in Germany (Palatinate) with:
One reach M+ device incl. Talysman Antenna (on Rover)
Samsung Galaxy S5 (on Rover)
Free RTK-Correction-Data from local SAPOS (Germany)
Everything is working perfectly. I walk in straight lines
with 1m-distances from point to point. (archaeological prospection)
I am planning to work abroad (Spain, Portugal, Tunisia) next year
and will not have any RTK-Correction-Data there.
My plan is to buy:
a second reach M+ incl. Talysman Antenna incl. LoRa Radio Antenna (as Base)
an aditional LoRa Radio Antenna for my actual M+ device (on Rover)
I will set up the base on a tripod in Averaged Single standalone mode without
additional corrections.
I will not have high absolute accuracy, but the relative measurements between base and
rover will be highly presice, which is all I need.
The rs2 will not do you any good with the M+ because it just L1. Wait to get the M2 then you can use it as a rover or on a drone if you come up with the right rig. Otherwise depending on your needs you can just get the RS+.
Yes you can use the RS2, but you lose the benefit of the dual. You can also run two M+, but you will not get the same range or performance in adverse scenarios. I have one of my M+ setup for drone and rover use and it was not as stable as an RS+ Rover and two M+ was is even worse. There are things that can be done to make them better, but I didn’t want to buy and more equipment.
Hi Michael, hi Christian,
Thanks for this information.
So I will go for the solution using two M+ devices…
Another question is the connection between base and rover:
Do I really need LoRa or can I connect with wifi or bluetooth?
The maximum distance between rover and base will be maximum 200 meter.
