Working with a UHF Radio on Reach RS4 / RS4 Pro
Reach RS4 / RS4 Pro features a built-in UHF radio that supports both transmitting and receiving RTK corrections, allowing you to use it as either a base or a rover in the field. The model supports integration with third-party receivers via the TrimTalk 450S* protocol, making it suitable for mixed-fleet setups.
In this support tip, you’ll learn how to use the UHF radio in your setup and choose the right configuration for your needs.
Overview and key considerations
The UHF radio in Reach RS4/RS4 Pro operates in the 410–470 MHz band, provides up to 2 W of output power, and works using the Trimtalk 450S protocol, with regional limits applied according to local regulations. In most regions, the Reach RS4 series ships with region-specific channel plans and power limits preconfigured in Emlid Flow to support compliant operation. Depending on your jurisdiction, UHF operation may still require a license. For example, in the US, you’ll need an FCC license—you can learn more in step 8 of How to set up RTK over UHF radio. To learn more information on the available frequency bands and output power, refer to the Reach RS4 and Reach RS4 Pro datasheets.
Let’s go through the possible UHF setups step by step.
How to set up RTK communication in a mixed fleet using UHF radio
Reach RS4 base and third-party rover
To set up RTK communication between your Reach RS4 / RS4 Pro base and a third-party rover over UHF radio, follow the steps from the dedicated guide in Docs and check out the tips below:
Third-party base and Reach RS4 as a rover
To set up RTK communication between your Reach RS4 / RS4 Pro rover and third-party base over UHF radio, follow the steps from the dedicated guide in Docs and check out the tips which will help you with the setup and operation:
How to set up RTK communication between two Reach receivers over UHF radio
You can set up RTK communication between two Reach receivers using a Reach RS4/RS4 Pro as the base, paired with either another Reach RS4/RS4 Pro or a Reach RS3 as the rover. When working with Reach RS3, you’ll need a compatible 410–470 MHz UHF antenna, which is sold separately in the Emlid Store.
To set up RTK communication over UHF radio, follow the steps from the dedicated guide in Docs and check out the tips which will help you with the setup and operation:
As for the baseline, it depends on the UHF transmitter power and setup. Reach RS4 can both transmit (up to 2 W) and receive corrections, so when used as a base, it defines the link.
*TRIMTALK is a trademark of Trimble Inc.
Have you tried similar setups or run into any challenges? Feel free to share your experience—your tips might help others in the field.
