Hello,
From what I saw on the starter guide, for the rover you need to input RTK settings, but if we are just going to do PPK with CORS corrections (i.e. no base) is there anything special we need to do for set up in the app?
If we just set the update rate to 1Hz and don`t connect a base we can still enable GNSS logging correct?
Hi Kris,
To work in PPK, you just need to record raw data log on your rover. Please check this guide to get all details on how to set it up in ReachView 3.
Hello @anna.moloko
Thank you! I was worried because understandably the base station is included in all mentions of the software and I was concerned it wouldn’t function properly if it was left blank.
