If for some reason my Reach RS+ start in hotspot mode, I start logging and I then want it to connect to a different network (in this case my phone, to get NTRIP corrections), it’s impossible.
If I enable my hotspot on my phone, the connection to ReachView is obviously broken.
ReachView won’t connect to a network that is not available, neither as a hidden point.
How do I switch from Reach RS+ hotspot to my own phone hotspot then?
What works best for me is to have the Known network turned on (meaning your phone) before booting up the Reach. Then it will connect right away. Once it is connected to the phone, then it seems to switch back to the the local wifi hotpot without issue (Reach Hotspot). If I have a base that I am not running any corrections on, then I have NO known networks entered into it. I have had nothing but problems when I entered my office wifi router as a known network, but by using only my Verizon Jetpack, it seems to work just fine especially if I have the Jetpack on before turning on the Reach RS.
But I guess I start them from the beginning and do not change the connection method (be it local hotspot or known network). I will do a test on my Reach RS (2.16.1) and see if I can toggle back and forth with no issues and let you know.
The problem is not the connection as such, but being able to make the connection from the GUI.
If I do your 1) I can’t do your 2) as I don’t have access to the RS+ any longer.
The fix is to let the user “connect” to a saved wifi, eventhough it might not be there at that exact moment. Let it seach for 30 s, while I can then start-up my mobile hotspot (which, as mentioned, makes me lose connection to the unit in the meantime).
