I cannot communicate the RS2 to the PC through the Wi-Fi network of the rech, in the cell phones if I can make the connection.
With my RS + I connect without problems to the PC, will there be any Wi-Fi configuration to be modified?
What firmware are you on?
with v 2.20.7 and 2.21.1 it does not connect
Have you had any changes to your local wifi?
Is it the rs2 trying to connect to the pc or vice versa?
Or is it a normal wlan/AP?
I go to Wi-Fi networks on the PC and connect the reach, I go to the browser and it never connects. I can’t detect the rech in fing
Sometimes there can be radio saturation issues. If one Wi-Fi device is too close, then it can drown out the signal coming from the others.
If you move RS2 1 or 2 meters away from PC, and phones, does that help?
I have it far, it is rare since in rs + it works well. Will there be any different network settings?
I’m not sure. I don’t think the settings are different between RS+ and RS2.
Thank you
Hi Luis,
May I ask you to share the screenshots of the issue occurring?
Would you mind elaborating on what exactly happens when you try to connect to the reach:XX:XX?
There you go. Just add some text
I didn’t understand how to do it
Thank you
you don’t want to share the video, this is after 28 hours of charging the led v2.21.1 continues to flash
But that’s a different issue, not related to wifi ?
Hi Luis,
May I ask you to elaborate on the issue? Is it not possible to turn the unit on after the charge? Would you mind describing the LED status in more detail?
Also, did you manage to connect Reach RS2 to the PC?
I also faced a similar problem with my router that it connects with phones but when I try to connected with pc it shows offline. And now after firmware update my problem enhance it now showing me [netgear password recovery]. If anyone has any idea about that problem then suggest to me about that router problem.
Try with changing your router password to a simple one by following theses steps
https://kb.netgear.com/000059608/How-do-I-reset-the-admin-password-on-my-NETGEAR-router
Also check that your router isn`t assigning IP 192.168.2.xx
Hi @chrishkyle7,
Have you had a chance to look at the solutions @Zinou and @TB_RTK suggested? Did it help?
Hi ! My problem is not with the Wi-Fi network, but with the rechview hostpot. It does not connect to start the Browser
