I am building a hexacopter using the Navio+ with APM software as flight controller. I am using a wifi connection to configure the board when it’s on the ground, or close to my laptop.
For controls I am using an FrSky RC system. Both The FrSky system and wifi operate at the same frequency of 2.4 gHz. Should I be worried about interference? Will this setup dramatically reduce the range of my FrSky system?
I would like to keep the on board wifi running during flight, as I will be using a second raspberry pi for data logging on the side. It will pick up the MavLink stream from the Navio+, together with some other sensors that are hooked up to the secondary Raspi. Or should I consider a wired serial link between the two boards and eliminate the wifi connection altogether?
Kind regards
