Today when I was working on a certain sector about 30 meters from the base, I lost connection to the ROVER and the rechview did not respond, I went to the state of the satellites and did not indicate any satellite bar. Then when I moved away it started to work well but when I go back to that sector it fails again. Attached reports of the base and the rover. I do not know if you want to connect to a nearby Wi-Fi network, I always have doubts about the hostpost. Use version V2.17.0SystemReport (1).zip (197.4 KB)
SystemReport.zip (215.3 KB)
What mode were your devices in? Hotspot?
How far were you from the rover device?
Do you have raw ubx logs from this test?
