When I turned on reach first time update process finished successfully. Now version 2.9.0
rfkill list
returns:
0: phy0: wlan
Soft blocked: no
Hard blocked: no
1: brcmfmac-wifi: wlan
Soft blocked: no
Hard blocked: no
2: bcm43xx Bluetooth: bluetooth
Soft blocked: yes
Hard blocked: no
I executed the following commands:
rfkill unblock wlan
ifconfig wlan0 up
systemctl stop hostapd && systemctl restart wpa_supplicant
What was going to happen after that? ifconfig
shows next:
root@emlid_base[~]# ifconfig
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:9079 errors:0 dropped:0 overruns:0 frame:0
TX packets:9079 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:621462 (606.8 KiB) TX bytes:621462 (606.8 KiB)
usb0 Link encap:Ethernet HWaddr 02:00:86:65:84:51
inet addr:192.168.2.15 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::86ff:fe65:8451/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:342 errors:0 dropped:9 overruns:0 frame:0
TX packets:256 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:41015 (40.0 KiB) TX bytes:58971 (57.5 KiB)
wlan0 Link encap:Ethernet HWaddr 90:b6:86:0e:3d:61
inet6 addr: fe80::92b6:86ff:fe0e:3d61/64 Scope:Link
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:9 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:1660 (1.6 KiB)
root@emlid_base[~]# journalctl -u reach_setup --no-pager
– Logs begin at Fri 2017-10-06 13:33:13 UTC, end at Fri 2017-10-06 13:34:15 UTC. –
Oct 06 13:33:18 emlid_base systemd[1]: Starting Emlid Reach setup…
Oct 06 13:33:18 emlid_base systemd[1]: Started Emlid Reach setup.
Oct 06 13:33:24 emlid_base reach_setup[246]: Traceback (most recent call last):
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/bin/init_network”, line 45, in
Oct 06 13:33:24 emlid_base reach_setup[246]: initialize()
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/bin/init_network”, line 31, in initialize
Oct 06 13:33:24 emlid_base reach_setup[246]: wifi_controller.turn_on_wifi()
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/site-packages/wificontrol/wificontrol.py”, line 60, in turn_on_wifi
Oct 06 13:33:24 emlid_base reach_setup[246]: self.wpasupplicant.start()
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/site-packages/wificontrol/wpasupplicant.py”, line 73, in start
Oct 06 13:33:24 emlid_base reach_setup[246]: self.execute_command(self.wpas_control(“start”))
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/site-packages/wificontrol/wificommon.py”, line 87, in execute_command
Oct 06 13:33:24 emlid_base reach_setup[246]: raise WiFiControlError(error_message)
Oct 06 13:33:24 emlid_base reach_setup[246]: wificontrol.wificommon.WiFiControlError: WiFiControl: subprocess call error
Oct 06 13:33:24 emlid_base reach_setup[246]: Return code: 1
Oct 06 13:33:24 emlid_base reach_setup[246]: Command: systemctl start wpa_supplicant.service && sleep 2
Oct 06 13:33:24 emlid_base reach_setup[246]: Exception in thread Thread-1:
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/threading.py”, line 551, in __bootstrap_inner
Oct 06 13:33:24 emlid_base reach_setup[246]: self.run()
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/threading.py”, line 504, in run
Oct 06 13:33:24 emlid_base reach_setup[246]: self.__target(*self.__args, **self.__kwargs)
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/site-packages/dev_utils/setup/reach_setup.py”, line 135, in _network_scan
Oct 06 13:33:24 emlid_base reach_setup[246]: Variables.network_status = subprocess.check_output(“init_network”)
Oct 06 13:33:24 emlid_base reach_setup[246]: File “/usr/lib/python2.7/subprocess.py”, line 544, in check_output
Oct 06 13:33:24 emlid_base reach_setup[246]: raise CalledProcessError(retcode, cmd, output=output)
Oct 06 13:33:24 emlid_base reach_setup[246]: CalledProcessError: Command ‘init_network’ returned non-zero exit status 1
Oct 06 13:33:26 emlid_base reach_setup[246]: u-blox:true,mpu:true,ltc:true,stc:true,lora:true
Oct 06 13:33:26 emlid_base reach_setup[246]: ReachRS
Oct 06 13:33:27 emlid_base reach_setup[246]: None
Oct 06 13:33:27 emlid_base reach_setup[246]: Error for wireless request “Set Power Management” (8B2C) :
Oct 06 13:33:27 emlid_base reach_setup[246]: SET failed on device wlan0 ; Input/output error.
Oct 06 13:33:34 emlid_base reach_setup[246]: (343) wsgi starting up on http://0.0.0.0:5000
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing main blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: Done
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing rtk_broadcasts blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing bluetooth blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing logging blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing wireless blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing gnss_updater blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing surveying blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: ----> Initializing configuration blueprint…
Oct 06 13:33:40 emlid_base reach_setup[246]: Received a new configuration to apply:
Oct 06 13:33:40 emlid_base reach_setup[246]: {‘base mode’: {‘base coordinates’: {‘accumulation’: u’2’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘antenna offset’: {‘east’: u’0’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘north’: u’0’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘up’: u’0’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘coordinates’: [u’55.7744304543’,
Oct 06 13:33:40 emlid_base reach_setup[246]: u’37.6292671483’,
Oct 06 13:33:40 emlid_base reach_setup[246]: u’185.464’],
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘format’: u’llh’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘mode’: u’single-and-hold’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘output’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘format’: u’rtcm3’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘path’: u’ntrips://:user@mycaster.com:8080/MOUNTPOINT#rtcm3’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘type’: u’ntrips’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘rtcm3 messages’: {‘1002’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘frequency’: u’5’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1006’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘frequency’: u’0.1’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1008’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘frequency’: u’1’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1010’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1019’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1020’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1097’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1107’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1117’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘1127’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘frequency’: u’1’}}},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘bluetooth’: {‘discoverable’: False, ‘enabled’: False, ‘pin’: 123456},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘correction input’: {‘input2’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘path’: u’test:user@mycaster.com:8080/MOUNTPOINT’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘send position to base’: u’off’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘type’: u’ntripcli’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘input3’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘path’: u’:9028’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘type’: u’tcpsvr’}},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘logging’: {‘base’: {‘format’: u’RTCM3’, ‘started’: True, ‘version’: None},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘correction’: {‘format’: u’RTCM3’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘started’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘version’: None},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘interval’: 24,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘overwrite’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘raw’: {‘format’: u’UBX’, ‘started’: True, ‘version’: None},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘solution’: {‘format’: u’LLH’, ‘started’: True, ‘version’: None}},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘lora’: {‘air rate’: 2.6000000000000001,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘frequency’: 868000,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘output power’: 20},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘position output’: {‘output1’: {‘enabled’: False,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘format’: u’nmea’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘path’: u’bluetooth’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘type’: u’bluetooth’},
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘output2’: {‘enabled’: True,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘path’: u’:2013’,
Oct 06 13:33:40 emlid_base reach_setup[246]: ‘rtk settings’: {‘elevation mask angle’: u’20’,
Oct 06 13:33:42 emlid_base reach_setup[246]: ‘glonass ar mode’: u’oService bt_daemon.service is not running.
Oct 06 13:33:46 emlid_base reach_setup[246]: (354) wsgi starting up on http://0.0.0.0:80
root@emlid_base[~]# journalctl -u wpa_supplicant --no-pager
Oct 06 13:33:23 emlid_base systemd[1]: Starting WPA supplicant service…
Oct 06 13:33:23 emlid_base wpa_supplicant[316]: Successfully initialized wpa_supplicant
Oct 06 13:33:23 emlid_base wpa_supplicant[316]: Line 22: failed to parse phase1 ‘peaplable=0’.
Oct 06 13:33:23 emlid_base wpa_supplicant[316]: Line 30: failed to parse network block.
Oct 06 13:33:23 emlid_base wpa_supplicant[316]: Failed to read or parse configuration ‘/etc/wpa_supplicant/wpa_supplicant.conf’.
Oct 06 13:33:23 emlid_base systemd[1]: wpa_supplicant.service: main process exited, code=exited, status=255/n/a
Oct 06 13:33:24 emlid_base systemd[1]: Failed to start WPA supplicant service.
Oct 06 13:33:24 emlid_base systemd[1]: Unit wpa_supplicant.service entered failed state.
Oct 06 13:34:14 emlid_base systemd[1]: Starting WPA supplicant service…
Oct 06 13:34:14 emlid_base systemd[1]: Started WPA supplicant service.
Oct 06 13:34:14 emlid_base wpa_supplicant[461]: Successfully initialized wpa_supplicant
Oct 06 13:34:14 emlid_base wpa_supplicant[461]: Line 22: failed to parse phase1 ‘peaplable=0’.
Oct 06 13:34:14 emlid_base wpa_supplicant[461]: Line 30: failed to parse network block.
Oct 06 13:34:14 emlid_base wpa_supplicant[461]: Failed to read or parse configuration ‘/etc/wpa_supplicant/wpa_supplicant.conf’.
Oct 06 13:34:14 emlid_base systemd[1]: wpa_supplicant.service: main process exited, code=exited, status=255/n/a
Oct 06 13:34:15 emlid_base systemd[1]: Unit wpa_supplicant.service entered failed state.
