Is it possible to have the Emlid automatically sign into a router automatically without singing in on 192.168.42.1 and going through the connection process?
yes, it is possible just add the router access point information like explained here:
https://docs.emlid.com/reach/common/reachview/#first-setup
yes I have it set up there, but it never connects when it boots. I have to sign into .42.1 and do it manually every time
hi blake, if you really set up reach there, try to pay attention to “power on” sequence. router is the first one which is must powered on, then reach.
gotcha. that may be the issue then. it may take a delay timer to the router gets booted up and starts it broadcast
Hi!
Did you get your issue resolved?
