Recently i have installed the RPI image from the emlid site on RPI 3 B. Most of the stuff works but the serious problem is WIFI. If i install RPI OS from the shelf ( NOOBS , xubuntu) wifi works fine out of the box .
On the emlid installation i am using the wicd-gtk GUI interface to connect which finds the relevant network , authenticates correctly but fails(drops) to connect .
I have exhausted all posible angles - BCM43143 driver, power management , manual set up via /etc/wpa_supplicant/wpa_supplicant.conf
Any ideas ?
Sasho
I had problems with this, too.
In the end I used wpa-supplicant, but the default file provided by emlid misses the " before and after the pre-shared key. Without them it did not work.
Tnx Sebastian - i bit lost - what do u mean âbeforeâ and âafterâ pre-shared key
This is the syntax i am aware of :
network={
ssid="The_ESSID_from_earlier"
psk=âYour_wifi_passwordâ
Exactly how you wrote it in your example.
The quotation marks have to be there.
The wpa-supplicant file on my RPi had quotation marks for the ssid, but not for the psk. I thought, that was the way it had to be and simply replaced the emlid ssid and psk with mine. That did not work.
Ifyou like, I upload my working version of the wpa-supplicant file later.
Guys, quotation marks are needed if you enter your password and they are not needed in case of entering the hashcode of one.
I guess, thatâs confusing. Sorry for that! Weâll fix it in the next image.
network={
ssid=âThe_ESSID_from_earlierâ
Or
network={
psk=hash â without quotation marks
Iâm very much used to adding new networks with a wpa_passphrase
utility. I suggest taking a look at it.
Tnx for the responses however i am using the syntax as per my email i.e properly quoted both ssid and the WAP 2 passphrase and the result is the same , authenticates and than drops the connection.
I really ran out of ideas. I did try completely fresh installation i.e dd again the image - and only addition is the conf file as per the above syntax
and alas no joyâŚ
btw - tried xubuntu - no problem connects straight out and works fine so the h/w is fine.
Guys finally i am done . No idea what was wrong - after numerous reboots - did ifdown wlan0 , ifup wlan0 and guess - all came to life . Rebooted and bang - wifi is up and running ! I have noticed on ifdown the interface released old ip so i guess this has something to do with it.
Many tnx - back to the real thing my sub drone .
Glad you got it sorted out!
