Since the last update, the hotspot mode does not move and does not allow me to connect to a Wi-Fi network, nor does it allow the two GPS to connect. Solution please.
When you select a WiFi network below it automatically turns off hotspot and then reboots the receiver to join the new WiFi connection.
Hi Carlos,
To switch your Reach device to a Wi-Fi network, you need to select it from the list of accessible networks and connect to it.
Also, I see that you are using not the latest software version with your Reach RS+. This January we released v2.22.3 that has many fixes since v2.18.1. I’d recommend updating your device.
I updated it, but it started to crash even more.
rs + goes off by itself. The last update fails a lot, they should make corrections, the fix does not hold.
Hi Carlos,
Since you’ve encountered these issues, may I ask you to send the following logs:
UBX logs from both base and rover recorded when the issue occurred
position log from the rover
base correction log from the rover
It could really help us to find out what’s wrong.
