Hello everyone,
My flight controller is a EMLID Edge, when I start the motors with the sticks, they stop after about half a second if you don’t push the stick up quickly enough.
Which parameters exactly do I have to change in the QGround Control software so that I can extend this time?
The issue is not yet clear to me. Do you mean that the motors don’t spin enough to generate enough thrust for take-off? If so, did you go through all the calibrations successfully?
Thanks for your answer!
I mean the time between i start with the throttle stick the engine and when i let the throttle down, than the motor stopps automatically.
This time is too short, i start the motors, than i must move the throttle stick instantly up, sometimes i cannot keep the motors armed and running, because the stopps instantly after i start it with the stick right down command.
