Hello, I am going to do research based on UAV. The attached picture is what I want to do with Navio2. Could anyone tell me where should I start? What material should I refer to?
Thanks!you could start by looking at the ardupilot source code GitHub - ArduPilot/ardupilot: ArduPlane, ArduCopter, ArduRover, ArduSub source
also have a look at GitHub - emlid/Navio2: C++ and Python sensor examples for developers
Thank you. I will try that
BTW, from your perspective, do you think it is possible to do that? Has someone else written their own code with ardupilot?
i have always wanted to program my own autopilot and i possibly will. i have done similar work in the area and programmed my own RC transmitter with expo channel reversing and everything you would see in a normal RC transmitter. its definitely possible. you will need to understand PID loops that’s why i told you to look at the source code to figure out how it works. i am still learning how it all works right now and will tell you my findings in the future. the main thing that is teaching me now is kerbal space program and a mod called kos scriptable auto pilot.
Thanks. I will work on that.
Hi ejohn,
Following is my idea to write my own code. Could you help me check whether it’s correct or not?
- Write my own subfunction
- Call it in the main function.
- Upload it in my own directory, for example: https://github.com/jason/ArduPilot/ardupilot.git
- Follow the instruction: https://docs.emlid.com/navio2/Navio-APM/building-from-sources/ to Building ArduPilot using Waf build system
is the procedure correct? I also failed to find the main function. Could you tell me the directory of main function?
Thanks!
