If you need data in real-time, then post-processing isn’t necessary. You can set an output and use the coordinates right away.
Post-Processing can be used to achieve more robust tracks for later review. In general, results achieved by processing raw logs are better, than the real-time solution. To download RINEX logs, make sure you’ve set raw data log option to file, and record a track. The log will be available in the logs tab.
