What is the best way to estimate how much battery power left?
Is it possible within the taranis Q7 display, or only in mission planner, what connection and cables do I need to each method?
Hello,
When you know how large is the battery, how long you fly, how much Amp you put back in it after flight, you could have an idea of how long you can fly with it.
There is a tool in Mission Planner to monitor Voltage and Current. You have to calibrate both Voltage and Current then set alarms.
Marc
