I recently started using a pair of Reach RS modules for gathering the position of ground control points for aerial drone photosurvey.
Today was our first day in the field with this setup, and it went pretty well! However, I realized when I started working on postprocessing my base module coordinates that I’d forgotten to write down the location that my base module had stored and used to establish relative distance to my rover! Are those coordinates stored anywhere, or am I out of luck?
As a workaround, I calculated the average of all raw base coordinates, calculated the average of all corrected coordinates (PPK with CORS), and subtracted one from the other in order to yield a generalized correction factor. However, I’d like to apply this factor to the actual stored coordinates of the base station if posible.
Thank you!
