Hello everyone.
I’m having problems wit integrating the Phantom 4 multispectral with corrections using EMLID caster. I don’t know where the issue is; whether the RS2 side or the drone side.
Error on the drone app says:
Weak RTK signal (8012)
It says its fixed, buy in yellow. This also happens with UgCS, here it says’: Connected. Not in use. ’ and also a message of ‘Weak RTK signal’
This happens some times, when I change battery it will either fix well or not, it doesn’t seem to change during the flight so far.
I tried restarting the drone, controller, ipad or android device connected to the controller. Couldn’t do the base because it is probably 1 km away, but same thin happened it being maybe 200 m away.
Didn’t have this trouble with P4R last week, and I’ve been using the same config on the RS2.
Thanks
