VTX connection to Navio2
Hey All,
I have a Walksnail Pro VTX with the GM3 gimbal and I would like to connect this to the Navio2, I’m currently using the UART TX/RX for a receiver Module (Radio Master DBR4 Xband Gemini). Is it possible to configure RX/TX to the VTX on the GPIO 17 & 18 Pins? Also is there somewhere on the board I can pull 9v+?
Is not fonctionnait and config no running
Hi Vincent!
Welcome to the forum!
Navio2 doesn’t have VTX or Video Out. We haven’t tested such a setup, so I can hardly suggest anything, but you can take a look at the Ardupilot article.
You can also connect the Raspberry Pi Camera Module to the Rasberry PI board directly by following this guide.
You cannot pull 9V on the Navio’s board.
