Hello everyone.
I would appreciate some help for my VTOL.
I connect the normal config connection setup on Navio2 and RX Futaba S-bus.
I turn on the Tx and the Rx it is green, means that the Rx and Tx are connected, binded and working, but when I turn on mission planner and try “Radio Calibration”, the radio is seems off.
Does any one know why?
Thanks. Andersson.
P.s. I will post about the jet aircraft with Navio2 as soon as possible.
Could you please post the output of emlidtool
and cat /sys/kernel/rcio/rcin/ch2
with a throttle stick moved all the way up?
ops… I don’t know. But I will open the raspberri again and check.
Ok, connected.
with throttle up 1924 and down is 1104.
It is working isn’t it?
Yep.
I just answered @Barry_Bolton on another thread about a similar problem. I guess there’s a chance you’ll find your answer over there.
Ops, my fault. I meam I cant see the TX Radio sending data to RX on Mission Planer. I turn on the Tx and the Rx it is green, means that the Rx and Tx are connected, binded and working, but when I turn on mission planner and try “Radio Calibration”, the radio is seems off.
Any idea?
But you can see the telemetry flow in MP? HUD is getting updated and so on?
…yes. I can see telemetry. In this case we are wi fi connected.
Hello @Andersson_Beccari
What is the version of your MP?
Can you reset to default your parameters and try again? (you should save them before reset)
version of mp 1.3.46.
Yes, i reset all parameters, and nothing.
Could you please also post the output of sudo update-alternatives --display arduplane
Ok, Ill do that. Today is going for hollyday in Brazil. Person in charge is not here anymore, but I will send it.
Thanks guys. All of you very gently. Well, thats why I prefer Navio…
Hello Bulatov.
I wrote it. The answer is…
Arduplane - Manual Mode
link currently points to /opt/ardupilot/navio/arduplane-3.7/bin/arduplane
/opt/ardupilot/navio/arduplane-3.7/bin/arduplane - priority 50
/opt/ardupilot/navio/arduplane-3.7/bin/arduplane - tri - priority 50
/opt/ardupilot/navio2/arduplane-3.7/bin/arduplane - priority 50
/opt/ardupilot/navio2/arduplane-3.7/bin/arduplane - tri - priority 50
Any idea?
Ok, ok, ok, DONE. RESOLVED.
We should write Navio 2 NOT Navio only.
Resolved.
Thanks guys for your help.
Thanks, Andersson
