Is it possible to do voltage sensing through the Navio2 Servo rail
Hi Barry,
In the meantime, you can measure only digital values using servo rail.
Hello Tatiana.
Let me be a little clearer
Can I use Qgroundcontol to measure the voltage over the servo rail and if so what would the setting in qgroundcontrol be?
Barry,
You can find the servo rail voltage in Widgets => MAVLink inspector window.
I’ve attached the screenshot.
OK but how do i select that under the settings to show on the ground station. while inflight
Barry,
In the meantime, you can see the the servo rail voltage only via MAVLink inspector window
