Dear Emlid Edge users,
i´m a new Emlid Edge user and i wish to transmit the image from my copter directly to an FPV monitor with HDMI input. Example: I have an FPV monitor direct on the transmitter and i need the image control direct on it.
Is this possible?
Or is the video transmission from my camery only possible direct to the pc into the QGround Control Software?
Thank you for your answers.
Hi @rcdevil,
If your transmitter can receive a signal via UDP, it should be possible to make such scheme work.
In that case, you just need to set EDGE video output to your transmitter.
