Vertical Datum
Right now I use NAVD88 (ftUS) EPSG CODE 6360 (geoid 18 but not labeled as such)
Does this include all lower 48 states, I see there are different EPSG codes for NAVD88
My concern is am I on the correct EPSG CODE 6360??
I work in Nevada and S. Utah FYI
Hi @mcwllc702,
I’d recommend the following setup in your case:
  • Choose a coordinate system for Nevada or Utah from our CS registry. For this registry, you’ll see USA below the system name.
  • Choose the NAVD88(GEOID18) height
  • Change Linear units to US Survey feet
