Hi everybody,
I’ve searched for a long time about how to use a USB camera on Emlid Edge. But I’m still stuck.
I’ve connected a USB camera on Edge’s USB 1 port. The device is available under:
/dev/video0
I was able to broadcast the video to my computer (and to see it) using this command, during ssh connection:
$ gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=640,height=480,framerate=\(fraction\)30/1 ! videoconvert ! jpegenc ! udpsink host=192.168.0.112 port=5000
Apparently, ‘/usr/bin/csd’ binary manages video streaming; 14% of CPU load when the video starts on QGC. This binary is released in firmware, so no access to the source code if I have understood correctly.
2 questions:
1- Is it possible to stream USB camera to QGC directly with GStreamer? In this case, if no HDMI camera is connected to Emlid Edge, does that make sense on CPU load?
2- If not, is it possible in Emlid Edge to modify a configuration file to use USB camera (for example /dev/video0) instead of HDMI-IN ?
Thank you.
