Using RS3 as Hotspot for Tablet
Hi All,
I’m helping a customer get setup with a new RS3. I’ve never used an internal SIM but they want to. Their goal is to have the Emlid provide internet as a hotspot to a Samsung Tablet. They have active SIM cards they’ve used in other devices so we know they work. They’ve tried both a Verizon and a T-Mobile. The Verizon didn’t connect at all but after adding fast.t-mobile.com for the APN, the T-Mobile card connected and allowed enabling data access over the mobile hotspot. We also were able to see that the Emlid was able to receive corrections from an RTK provider.
The problem is that the tablet keeps disconnecting from the Emlid and losing the data connection from the wi-fi hotspot of the Emlid.
Anyone able to use the RS3 with a SIM card as a mobile hotspot for an android tablet or phone?
Tablets tested were:
  1. Samsung Galaxy Tab A
  2. Samsung Galaxy Tab Active4 Pro (model SM-T630)
I’ve included the simple system report from the RS3 below.
Thanks!
Simple system report
app version: 31.8-r0
current_network:
  ip: 172.20.10.6
  security: wpa-psk
  ssid: "Quintin\u2019s iPhone (2)"
enabled: true
mode: client
base_mode:
  base_coordinates:
    accumulation: 120
    antenna_offset: 0
    coordinates:
      height: 0
      latitude: 0
      longitude: 0
    mode: single-and-hold
  output:
    io_type: tcpsvr
    settings:
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcaster:
        mount_point: REACH
        password: '***'
        port: 2101
        username: reach
      ntripsvr:
        address: ''
        mount_point: ''
        password: '***'
        port: -1
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 9001
      tcpsvr:
        port: 9000
  rtcm3_messages:
    message_1004:
      enabled: false
      frequency: 1
    message_1006:
      enabled: true
      frequency: 0.1
    message_1008:
      enabled: false
      frequency: 0.1
    message_1012:
      enabled: false
      frequency: 1
    message_1033:
      enabled: false
      frequency: 0.1
    message_1074:
      enabled: true
      frequency: 0.5
    message_1084:
      enabled: true
      frequency: 0.5
    message_1094:
      enabled: true
      frequency: 0.5
    message_1124:
      enabled: true
      frequency: 0.5
    message_1230:
      enabled: true
      frequency: 0.1
bluetooth:
  enabled: true
  pairing:
    discoverable: true
    no_input_no_output: true
    pin: '***'
correction_input:
  base_corrections:
    io_type: ntripcli
    settings:
      bluetooth:
        send_position_to_base: false
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcli:
        address: 40.121.5.206
        mount_point: RTCM3_IMAX
        password: '***'
        port: 10000
        send_position_to_base: true
        username: sssolutions
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 10001
      tcpsvr:
        port: 10000
      uhf_radio:
        bandwidth: 25
        frequency: 438000000
device:
  privacy_policy_accepted: true
  role: null
  rv3_banner_shown: false
  usage_analysis_accepted: true
logging:
  logs:
    autostart: true
    base:
      enabled: true
      format: RTCM3
    raw:
      enabled: true
      format: RINEX
      rinex_options:
        logging_interval: 0
        marker_name: null
        pole_height: null
        preset: default
        satellite_systems:
          beidou: true
          galileo: true
          glonass: true
          gps: true
          qzss: true
          sbas: false
        time_adjustments_enabled: true
      version: '3.03'
    solution:
      enabled: true
      format: LLH
    started: true
  settings:
    interval: 24
    overwrite: true
    simultaneous_logging: false
network:
  tcp_over_modem: false
position_output:
  output1:
    io_type: bluetooth
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
  output2:
    io_type: tcpsvr
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
positioning_settings:
  elevation_mask_angle: 15
  glonass_ar_mode: false
  gnss_settings:
    positioning_systems:
      beidou: true
      galileo: true
      glonass: true
      gps: true
      qzss: true
    update_rate: 5
  gps_ar_mode: fix-and-hold
  max_vertical_acceleration: 1
  positioning_mode: kinematic
  snr_mask: 35
  tilt_compensation:
    enabled: false
    logging: false
sound:
  mute: false
  volume: 100
[/details][details=“Simple system report”]
current_network:
  ip: 172.20.10.6
  security: wpa-psk
enabled: true
mode: client
base_mode:
  base_coordinates:
    accumulation: 120
    antenna_offset: 0
    coordinates:
      height: 0
      latitude: 0
      longitude: 0
  output:
    io_type: tcpsvr
    settings:
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcaster:
        mount_point: REACH
        password: '***'
        port: 2101
        username: reach
      ntripsvr:
        address: ''
        mount_point: ''
        password: '***'
        port: -1
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 9001
      tcpsvr:
        port: 9000
  rtcm3_messages:
    message_1004:
      enabled: false
      frequency: 1
    message_1006:
      enabled: true
      frequency: 0.1
    message_1008:
      enabled: false
      frequency: 0.1
    message_1012:
      enabled: false
      frequency: 1
    message_1033:
      enabled: false
      frequency: 0.1
    message_1074:
      enabled: true
      frequency: 0.5
    message_1084:
      enabled: true
      frequency: 0.5
    message_1094:
      enabled: true
      frequency: 0.5
    message_1124:
      enabled: true
      frequency: 0.5
    message_1230:
      enabled: true
      frequency: 0.1
bluetooth:
  enabled: true
  pairing:
    discoverable: true
    pin: '***'
correction_input:
  base_corrections:
    io_type: ntripcli
    settings:
      bluetooth:
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcli:
        password: '***'
        port: 10000
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 10001
      tcpsvr:
        port: 10000
      uhf_radio:
        bandwidth: 25
device:
  role: null
logging:
  logs:
    autostart: true
    base:
      enabled: true
      format: RTCM3
    raw:
      enabled: true
      format: RINEX
      rinex_options:
        logging_interval: 0
        marker_name: null
        pole_height: null
        preset: default
        satellite_systems:
          beidou: true
          galileo: true
          glonass: true
          gps: true
          qzss: true
          sbas: false
      version: '3.03'
    solution:
      enabled: true
      format: LLH
    started: true
  settings:
    interval: 24
    overwrite: true
network:
position_output:
  output1:
    io_type: bluetooth
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
  output2:
    io_type: tcpsvr
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
  gnss_settings:
      beidou: true
      galileo: true
      glonass: true
      gps: true
      qzss: true
    update_rate: 5
  snr_mask: 35
  tilt_compensation:
    enabled: false
    logging: false
sound:
  mute: false
  volume: 100
current_network:
  ip: 172.20.10.6
  security: wpa-psk
enabled: true
mode: client
base_mode:
  base_coordinates:
    accumulation: 120
    antenna_offset: 0
    coordinates:
      height: 0
      latitude: 0
      longitude: 0
  output:
    io_type: tcpsvr
    settings:
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcaster:
        mount_point: REACH
        password: '***'
        port: 2101
        username: reach
      ntripsvr:
        address: ''
        mount_point: ''
        password: '***'
        port: -1
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 9001
      tcpsvr:
        port: 9000
  rtcm3_messages:
    message_1004:
      enabled: false
      frequency: 1
    message_1006:
      enabled: true
      frequency: 0.1
    message_1008:
      enabled: false
      frequency: 0.1
    message_1012:
      enabled: false
      frequency: 1
    message_1033:
      enabled: false
      frequency: 0.1
    message_1074:
      enabled: true
      frequency: 0.5
    message_1084:
      enabled: true
      frequency: 0.5
    message_1094:
      enabled: true
      frequency: 0.5
    message_1124:
      enabled: true
      frequency: 0.5
    message_1230:
      enabled: true
      frequency: 0.1
bluetooth:
  enabled: true
  pairing:
    discoverable: true
    pin: '***'
correction_input:
  base_corrections:
    io_type: ntripcli
    settings:
      bluetooth:
      lora:
        air_rate: 9.11
        frequency: 902000
        output_power: 20
      ntripcli:
        password: '***'
        port: 10000
      serial:
        baud_rate: 38400
        device: ttyEXTS0
      tcpcli:
        address: localhost
        port: 10001
      tcpsvr:
        port: 10000
      uhf_radio:
        bandwidth: 25
device:
  role: null
logging:
  logs:
    autostart: true
    base:
      enabled: true
      format: RTCM3
    raw:
      enabled: true
      format: RINEX
      rinex_options:
        logging_interval: 0
        marker_name: null
        pole_height: null
        preset: default
        satellite_systems:
          beidou: true
          galileo: true
          glonass: true
          gps: true
          qzss: true
          sbas: false
      version: '3.03'
    solution:
      enabled: true
      format: LLH
    started: true
  settings:
    interval: 24
    overwrite: true
network:
position_output:
  output1:
    io_type: bluetooth
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
  output2:
    io_type: tcpsvr
    nmea_settings:
      bluetooth:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      serial:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpcli:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
      tcpsvr:
        ebp:
          enabled: true
          update_rate: 1
        etc:
          enabled: true
          update_rate: 1
        gga:
          enabled: true
          update_rate: 1
        gsa:
          enabled: true
          update_rate: 1
        gst:
          enabled: true
          update_rate: 1
        gsv:
          enabled: true
          update_rate: 1
        main_talker_id: gn
        rmc:
          enabled: true
          update_rate: 1
        vtg:
          enabled: true
          update_rate: 1
        zda:
          enabled: true
          update_rate: 1
    settings:
      bluetooth:
        format: NMEA
      serial:
        baud_rate: 38400
        device: ttyEXTS0
        format: ERB
      tcpcli:
        address: localhost
        format: ERB
        port: 9000
      tcpsvr:
        format: LLH
        port: 9001
  gnss_settings:
      beidou: true
      galileo: true
      glonass: true
      gps: true
      qzss: true
    update_rate: 5
  snr_mask: 35
  tilt_compensation:
    enabled: false
    logging: false
sound:
  mute: false
  volume: 100
Hi Doug!
Welcome to the forum!
We’re working on providing a solution for RS3 to work with the Verizon SIM cards. I’ll let you know once there are any updates.
Regarding the sharing the mobile data, you could insert a SIM card into the mobile phone and connect your Reach to the Internet that way as a workaround. I’ve also written you a PM as further troubleshooting will require sensitive information.
Thank you Olesia,
They have been using the workaround but they’d like to use a tablet that does not have a SIM slot in the future. Also, It often takes a minute to get the Emlid to get the corrections coming in when using the Tablet’s wifi.
Got it, Doug. Then, let’s continue our investigation over PM.
Is it a known problem when the SIM is from Verizon?
I am experiencing the same issue with constant dropped connectivity.
When I turn on the hotspot, it works for a few minutes and drops the connection. After 5 minutes or so, it is possible to connect again, yet it will drop the connection in a few minutes again. Thus, it is a constant never-ending cycle.
Dan,
Yes, there’re some restrictions from Verizon’s side. We’re working on resolving them for the Reach RS3, but there are no ETAs I can share with you. In the meantime, you can check SIM cards that worked for some of our users from the USA: AT&T (data+voice plan) and EIOTCLUB/Twilio/SPECTRUM SIM cards.
I tried two different plans with different SIM cards from Verizon, and in every case, I had the same problem with instability. Verizon is very picky with devices not officially approved for use on their network; thus, their system might be temporarily blocking connections, which triggers RS3 to reset the hotspot. At least, this is my current theory.
