Thank you for some insights from the posts above. I am just linking into this thread because it covers one of my issues. I want to use a Reach RS+ system (3-4 Rovers, one fix) and will have to use them closed by a 100m high wind turbine whose tower base has a diameter of 6m. So I am wondering if that obstacle will affect the quality of the measurement campaign or if the obstacle which is only on one side of the rover wouldn´t influence it to much. Are there any experiences, of how close I could come to that obstacle until lacking from tracking loss?
I regularly work around data poles and high-voltage transmission lines. I think the objects are so narrow and not close enough together that it doesn’t affect the fix to the point that causes bad data.
