I’m wondering if it would be possible to use the NAVIO2 with an Odroid C2 using an external USB to SPI converter. Is it possible to get the schematic of the connection between the RPI and GPS chip?
What are you thought on this approach? Is there a better way?
@t3ea In theory, yes. But in reality it would take too much effort to make everything run smoothly.
The connection of the sensors can be found in the docs on the pinout. Each pin is named accordingly to which pin of the sensor\chip it is connected to.
