Hi all,
I probably need to use Emlid Rover-Base in very remote areas where I will not have Wifi or GSM connection.
I need to log raw data of both Rover and Base, and RTK solutions (the connection between Rover-Base will be via 3DR radio ).
If I turn off the Wifi (in order to avoid that Emlid behaves as AP) and I supply power to both devices can I expect that they run the last configuration I saved in both of them (hence, kinematic mode, raw data and solution log etc.)?
Thank you in advance for your help,
E.
