Sure, if both receivers work with RTCM3 correction format, they can be an RTK team
Note that to use UHF, you’ll need an external radio for RS2. The ones that allow Serial communication over USB or RS-232 will do.
RS2 can broadcast corrections over the Internet. As Christian mentioned, you’ll be fine working with Emlid Caster for this: it’s a way to connect your base and rover over the internet. So if your receiver supports NTRIP, there will be no issues with such integration.
Sure, if we’re talking about NTRIP connection. No need for the static IP on Reach’s side.
You can either connect Reach to the external network or use its mobile hotspot. The choice is yours. You can go to our docs on either SIM connection or via Wi-Fi to check this out.
Reach works with 2G and 3G GSM SIM cards. There may be other requirements from the operator, like entering the APN or even using the user/password authentication on your SIM. All of these are supported in ReachView 3, though.
You can connect the base to an external cell modem that works with whatever static ip sim you want, connect by wifi or 232 or bluetooth if the external modem has it.
or use generic sim and Emild caster as previously described
Well, there you have it, then. That’s indeed a thing: you need to use the GSM SIMs.
I’d also back up what @PotatoFarmer said. It’s possible to work with external 4G modems if that’s required. The network requirements are not that stiff, in this case.
