Will the Emlid RS2 be able to carry out pos. as nmea over UDP? Been told from the Waterlinked support that i need that to be able to get pos. over UDP.
Do you have a Linux box in the network?
Easily convert from TCP to UDP with socat. for example:
socat -u UDP4-LISTEN:9000,bind=192.168.20.1 TCP4:192.168.20.22:9000,fork
Hi @post,
By default, Reach RS2 supports outputting its position via TCP.
However, the method suggested by @bide should work fine.
