schematic:\
Tiny module is a PWM Solenoids and Valves driver using Texas instrument’s DRV103 low-side DMOS power switch employing a pulse-width modulated (PWM) output. Its rugged design is optimized for driving electromechanical devices such as valves, solenoids, relays, actuators, motors and positioners. This board is also ideal for driving thermal devices such as heaters, coolers, lamps, PWM operation conserves power and reduces heat rise, resulting in higher reliability. In addition, adjustable PWM allows fine control of power delivered to the load. Output delay time and oscillator frequency are also externally adjustable.
![image](https://community.emlid.com/uploads/default/original/2X/6/6039961eba5fe199f36b30d21a16566f5c5e3ad3.jpg)
Features Supply 8V to 32V DCLoad Capacity 1.5ATrigger Input Voltage 1.5V to 5V DCThermal and Current Limit ShutdownOn Board Power LEDApplications SolenoidsValves,Heaters, CoolersLampsRelaysPower Contactor CoilsHydraulics and Pneumatics Systems
Note: PWM Duty Cycle, Output Delay, Frequency Adjust
Oscillator Frequency range 500Hz to 100Khz, default set to 5Khz, Frequency can be alter by changing R4 ( Refer Data sheet for more details)Delay Output: Default delay set to approx. 100mili seconds, Delay can be adjust by changing Capacitor C1Duty Cycle is adjustable 10% to 95% , default set to 95% can be alter by changing R3 (Refer Data sheet for more details)
3686
Project tested
Solenoid-driver-PIC
Oscillator Frequency range 500Hz to 100Khz, default set to 5Khz, Frequency can be alter by changing R4 ( Refer Data sheet for more details)Delay Output: Default delay set to approx. 100mili seconds, Delay can be adjust by changing Capacitor C1Duty Cycle is adjustable 10% to 95% , default set to 95% can be alter by changing R3 (Refer Data sheet for more details) Schematic
Solenoid-and-Valve-Driver-SCH
Parts List
Photos:
