Is it possible to connect reach to a dsl modem or router?
can i give a fixed ip accorting to my system to reach? eg. 192.168.178.xx x=reach
andreas
andreas
Hi!
Well, you can connect Reach to any Wi-Fi router. Regarding wired connection, you may connect it via Ethernet USB, which will work with a Linux computer. For example, OpenWRT router might be considered one.
Regarding static IP, this is a router settings, you will need to go to its web interface, find Reach in the connected devices and add a fixed IP for it.
i use a fritz.box. it´s from germany and linux based. if i use wi-fi i see reach and can add a fixed ip for it.
if i turn of wifi on the fritz.box und i try to connect via etherned usb i got no sucess…
the ip should assigned thrue dhcp:
i think the reason is my router uses ip adresses from 192.168.178.1 to 192.168.178.200…
intel edison 192.168.2.2…
i have found this on communities.intel.com and try it:
DHCP you could also easily switch on by starting connman:
systemctl enable connman && systemctl start connman
Is a wired connection direct to router standard RJ45 port possible? I want a more stable Internet connection than WiFi. This is for a permanent base station.
Do any of the USB to Ethernet adapters offer Reach wired Internet? Does Reach have drivers for these adapters?
You are in a hotel room in a far-away city and you need to access the internet through your tablet. But there’s no WIFI! Only a hard-wired Ethernet connection. What do you do? In the past, with many popular tablets, you could reach for your trusty...
Hi did you ever get this fixed. I’m trying to setup a REACH as a CORS too and want to connect directly to our network lab using a dlink adaptor. I have a fixed IP allocated for the receiver that I want to add. It’s seems a bit messy when not using WiFi to connect to a lan network.
Thanks
Conor
There is some info here in this post: I have two USB to RJ45 adapters here and I have just tested them for you on my Reach RS: WORKING D-Link; model DUB-E100; USB 2.0 Fast Ethernet Adapter (10/100Mbps) linux driver: asix idVendor=2001, idProduct=1a02 NOT WORKING no name brand;...
Community Forum
Connecting Reach RTK to Laptop using a Ethernet RJ45 Connector
I would recommend against connecting Reach directly to a modem. Make sure Reach is behind a firewall (router) as it is not hardened for exposure to the WAN, nor should it have to deal with fending off constant botnet attacks. It’s granted that some modems have built-in firewalls though.
You might know that already, but I’m saying it for everyone that reads this.
