Windows 10 is not recognizing USB Telemetry Receiver device.
I have installed the driver for it. It is identified as Silicon Labs CP210x device. I installed CP210x device_Universal_Windows_Driver for it. It was identified by Windows few times in the beginning. But now, each time I disconnect and then connect it back, Windows does not recognize the USB device. I tried to uninstall drivers, disable/enable device, reboot, try other USB ports but nothing helps. I keep getting the message Unidentified USB device. Any help will be appreciated.
My FPV Radio Telemetry Ground Module was defective. I tried on a different laptop and it did not work there either. So I replaced the Radio Telemetry Ground Module and it has been working since.
I have connected my FPV radio telemetry Ground Module to my laptop (which I am using as a Ground Station) via USB port. I have mission planner installed on this laptop.
