Both units updated to latest version and only UART is given as a serial input/output option. How do you setup for usb input?
USB option is shown dynamically if a USB device, which supports serial profile (like 3dr radio) is connected over USB OTG.
Wifi wont broadcast when I connect an OTG so I cant see the dynamically generated menu option using a 2amp 5v power supply to df13
power supply issue solved and all is working! Thanks
Edison Windows drivers installed a version of usbser.sys and Reach now shows up as a serial COM port when connected (as well as MSC & RNDIS). However the USB option still doesn’t show up in ReachView UI. How to configure the ttyUSB0 for serial output?
I use usbser with other devices, mostly with ARM micros (STM32/Freescale).
Thanks,
-Max
Max, we do not currently support serial over USB port on Reach in client mode. The USB option is used when you plug in usb devices in the OTG mode. As shown here:
Having a serial profile will be a good addition, but it is not very straightforward and there is already RNDIS in place, which lets you have a full network connection and stream data over TCP.
