do you guys have so many crashes during the update of your antenna? Message :
“Failed to perform Update”
I am trying to install the 2.22.4 from the 2.22.3, and I get the same problem before when I upgraded to the 2.22.3, and also from the previous version, every update is a nightmare… the step “downloading” is so long (more than 40 min) and crash after. So after maybe 15 tries, sometimes, my antenna finishes updating… I tried from the ios app, from the web explorer, from different wifi and also from the mobile network… I will finish by trow all of this stuff by the windows I think… I have the same problem on the reach RS+ and RS2…
I finally succeeded to update the antenna but not from the “normal” way.
After many tries, the antenna got stuck during the boot time, the LEDs were doing a (crawling) moving line indefinitely. So I had to back up my data inside with ssh and perform a firmware flash with the emlid tool software. So I get the 2.22.4 but the dev version still refuses to install, the version showed is the 2.23.5 even before the firmware flash the system proposed to me the 2.23.6…
