I have two Emlid Reach RS+ antennas, base antenna and rover antenna.
The rover antenna is updated to version 31.7 and the base antenna has version 29.2, but when searching for firmware updates it says that the firmware is updated, even though they are the same antennas.
I have tried the reflashing firmware method but in the process the antenna disconnects and connects from the USB and generates an error at the end.
Yes, and if the firmware flash is not successful, I believe it will revert to the previously-installed version.
So it might also be useful to try the firmware flash again, in different ways:
different USB cable
different USB port on computer
and maybe try a different kind of computer
Also, think about cleaning the USB port in the Reach RS+.
In the electronics industry, isopropyl (rubbing) alcohol is frequently used for cleaning parts, and something like a toothbrush can help to scrub any debris off of contacts. Let it air-dry, or blow air in the socket to make it dry faster.
