On a recent project where we operated with a RS2 rover receiver and a RS2 base receiver (with NTRIP caster) we noticed wrong records in the CSV file of the project exported.
the receiver was set up to receive correction from the base via a NTRIP caster. (ie: We use the NTRIP EMLID CASTER).
the issue we noticed into the csv is a survey point set as FIXED whereas the accuracy fields stored in the csv were very high. How come ReachVIEW is able to set to FIX Statue with that kind of accuracy ?
would it be possible to check why the RS2 receiver can return FIX solution whereas accuracy threshold is not reach at all ?
how does it work in ReachView ? How can it be possible that a csv project file stored such record ?
thanks,
antoine
