Hi there,
I encounter a problem trying to tag corrected data to pictures. Emlid studio detected 671 images but my folder consists of 672 images. Because of this i am unable to tag and update exif files.
It is much appreciated if you could take a look the problem. Or Help to tag the images if possible.
Alright, then we can likely rule out hardware problems.
You can try removing the first or the last trigger event in the mrk-file. If the event is positioned within the sequence, it is much harder to identify though :S
I checked the images and found a duplicate image of _305. I then crossed check with .mrk file and confirmed that the duplicate was not recorded in .mrk file & deleted it. Once deleted, the tagging went smoothly.
I did not delete the 1st or the last image (it seems to be a simple way out) as i do not know how emlid’s algorithm tags images.
If the photos’ number matches the events’ number, Emlid Studio will geotag them. But I’m not sure if this would be correct because it doesn’t matter what image you’ll delete: the main thing is the total number of photos. So the same set of coordinates can be applied to different sets of images.
